where can i get body mount bushings for 94 ext cab?
calebrk
va
I just put a 3 inch body lift on yesterday. I need new body bushings. Advance auto doesn't carry them.
Is it possible to make them? Have any of you done it?
Thanks for any help.
you can by a set of poly bushings on summit racing for about 30 bucks if i remember right... that's what i did when i did mine...
hey all,
i just got the idea to make my own rubber bushings out of an old tire i have. have you seen this done?
Homemade body mount bushings out of tire
This evening i made em. I took an old tire and with a portable band saw, i cut the sidewall off, then cut that into 3 pieces. From there, i took one at a time, put it in a vice and "sloppily" cut squares out. IMO, it did not matter one bit what they looked like. some are more triangular, some are actual squares. Since i had already put the 3 inch lift blocks in, it wasn't hard to put the rubber "bushings" in. I just unbolted the 3 on the drivers side, lifted the front with an engine lift and jacked near the back of the cab underneath. I then put two pieces of tire on top of each block and one under each one. I then did the same to the passenger's side, then retightened everything and i just got back from driving about 25 miles. It rode SO MUCH BETTER than without the pieces of tire. Is this completely stupid and unsafe or am i onto a good idea? Oh, it only took me about 2 hrs by myself to do all this. Not very long in my mind....
Ill try to get pics of the project this week.
BTW, i kno that i can pay $50 for some from summit. But i'm only 18 and i can't justify spending that money on something i can make for free and with a little effort.
Thank you.
It rode great to work today! I think my new invention is one that will stick?
Question: i put the PA 3 inch BL on. I tried to put the steering extension in after the lift and the steering shaft WOULD NOT seperate. Have you run into this? What should I do. I can tell the steering is looser now and it feels very sloppy. I really don't think it's from having the lift on in general. Im pretty sure i need to extend the shaft.
Thanks for any help,
calebk
