Where can I find ABS Codes?
BillRod
Colorado Springs CO
Hi All
Where can I find the ABS codes?
My Wife's 94 Ranger started flashing the ABS light today.
15 short flashes and the 16th is longer.
MC is full and the truck appears to be braking/stopping fine.
Are the codes listed anywhere on this site?
Or has anyone had this same issue that can point me in the right direction?
Thanks
Bill
94 Ranger, 4.0L Pushrod, 5 speed, 4x4, ext cab.
That code is "16" No problem found. (I know. Funny that the system would flash an error code to tell you there is no error.)
I checked it out in my 93 service manual. It said if this code is flashing when you start the truck, the Keep Alive Memory does not have power. The codes are clearing every time the truck is shut off, so the ECM is running a self test and telling you the system is ok. There is a fuse for this. Find and check it.
