When I catch the creep...
It is an automatic, can water leak into the trans cooler? How
if the casing of the radiator or the pastic inside the cooler breaks it can leak into the cooler , you can tell if it has by cheching your trans fluid , if it looks like a strawberry milkshake you are in trouble , but that still does not explain how you are loosing water :icon_confused: :icon_confused: , usually if youy have a blown head gasket or cracked tranny cooler you get the symptoms in both places , you never loose fluid , it just turns to shit
a quick question , have you checked your expansion/overflow tank and the line going to it ?
