if the casing of the radiator or the pastic inside the cooler breaks it can leak into the cooler , you can tell if it has by cheching your trans fluid , if it looks like a strawberry milkshake you are in trouble , but that still does not explain how you are loosing water , usually if youy have a blown head gasket or cracked tranny cooler you get the symptoms in both places , you never loose fluid , it just turns to shit
a quick question , have you checked your expansion/overflow tank and the line going to it ?
