Yes they will... providing you previously install longer studs and spacers.
They both come with the same bolt pattern (5X4.5) but the front wheel drive rims are off centered toward the outside of the rim. This means they have a bigger backspacing causing the tires to go toward the inside of your truck. This will modify the performance of the truck's handling abilities plus the big possibility of the tires hiting fender wells or other parts.
Besides the truck will look very ugly with it's tires way in there.
For
