My pass side has been roaring going down the road jacked it up today and i can twist it side to side less than 1/4 of a inch .. are the wheelbearing toast or am i looking at wrong thing?
No, I think those are sealed. But you still should make sure the play is in the wheel bearing before you try to replace it. Tie rod ends are also likely candidates. Also check the stupid stuff like loose lugnuts. Don't laugh too hard; it happens.
its a sealed unit if it is 4wd, if it is 2wd then it is a tapered bearing setup. When you ask a question it is helpfull if you include some basic information about your truck.
One thing that i notice when wheel bearings are going,with that much play is that you should notice your breaks feel funky like you should have to give it an extra pump on the break peddle. Not only should you check side to side but top and bottom as well. Its not a hard job if you have to replace them anyways.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
