wheel offset
ray1234
Banned
--- Banned ---
hello i want to put 31 inch tire on my bronco 2 1988 4x4 but i need new rims
what the rims size and offset is needed:3gears:: ???
if u have a stock b2 u most likely cant fit 31s and whatever size rims u wanna use and also i would do with a 3 inch offset aka back spacing
scuse me im french
do you mean that i cant fit 31
I fit 31x10.5r15 Baja Claws on stock rims on stock suspension. It rubs occasionally but the springs and coils aren't good.
Richard
wow on my 84 b2 i cant fit 31s until i get coil spacers and what it means ray is they will rub or u wont be able turn cause they are to big but i stand corrected so go ahead and get yourself a set of 15x8 rims with a back space of 3 inches and u should be good
i got 31 10.50 15 with stock suspenion and stocks rims on my 86b2 they rub a bit but they still fit
you fit a 10.5 on a 5.5 rims ????
31x10.5r15"
stock rbv rim but unsure about application
'85 b-II
Finaly i buy 235x75x15 its a little bigger than stock tire
