Wheel bearings
konstrukt
So I have replaced my wheel bearings once when they rusted out. That was when I had my torsion bars cranked. I lowered it back down when I installed new wheel bearings. Now my wheel bearings have gone out again. There is too much play in the steering wheel. What will make my wheel bearings last longer? Should I replace other parts along with the wheel bearings? Are there heavy duty off road wheel bearings? Also, are 4x4 wheel bearings the same or different? Thanks
make sure the wheel bearings are properly pre loaded. also if you are running wheel spacers, or have allot of back spacing putting the wheel further out then that will cause premature bearing failure. be extremely clean when replacing and use proper grease. i highly recommend the lucas. good luck.
