mikhail
Im comming home from school, I noticed a slight wobble on a turn in the parking lot, I shouldve stopped there to check it. I knew my wheel bearings were kinda bad, they wobble a little so i figured it was fine and kept going. I go down the road then make a right turn, I thought it was making a weird sound, but the brake pad had come out of the caliper yesterday, so i figured it was something with the brakes again, ill check it when i get home, its only 2 blocks. Well im comming to a stop sign so i start to brake, and it all happens at once. I see a wheel lug fall off, the tire wobbles, i feel it in the steering, hit the brakes more, the tire comes off and bam the rotor hits the ground. I slide about a foot on the rotor. Scary as hell, I was thinking its fucked, and who loosened my lug nuts!!?
I had taken the tire off yesterday to fix the brake pad, im almost positive I torqued down the lug nuts. This is also the wheel with the broken hub. I figured the squeaking sound was because of the broken hub on Saturday, then the bakes on Sunday, now im thinking it was the wheel bearings. Either way i had to change them, when i put the tire back on i noticed it was wobly as hell and it wasnt the ball joint. It may have been from hitting the ground so hard, but i know it was bad before then.
Its pretty scary seeing a wheel come off while youre driving, I was lucky it was right at a stop sign and not on the street before where i was doing 35mph+ I can only imagine what wouldve happened then.
BTW, does anyone know if bad wheel bearings can cause the lugs to come loose, or was it someone trying to kill me? I think the brake pad comming off, the wheel comming off and the wheel bearings are all connected.
