whats the name of ????
parabellum1130
pa.
I have a 94 2wd ranger ex cab and im doing a djm 3/4 drop
I finished up the rear flip and redid every nut bolt bushing shackle n perch ..
now im on the front got about 90 percent apart and im starting to order all the bushings and stuff needed to be replaced ....
here my ?? attached between ibeams and frame is radius arm ( believe its called ) I need to know the exact bushing name that go between radius arm and frame ....
I called advanced to get a price and he said he not finding it in pc mayb its called something else ..... pretty sure its called radius arm bushing or am I wrong?? I hate calling local part stores , I argued wit a guy once telling me front and rear bushing on rear leaf are the same pointing at pc screen cuz it had same part number ....
also on radius arm the shock mount snapped off when I was removing it is that stud replaceable on the arm or do I need a new arm ...???...
so I guess all 155 people that viewed this didn't have any answer ...
I appreciate all your help , I don't know what id do without yall
I believe the bushing is called a radius arm bushing.
There are replacement studs. I found mine at the local parts place in the "help" section. "help" is a brand name of small auto parts such as knobs, interior pieces, shock bushings, etc.
Stifle your sarcasm here and ask your question in another Ranger forum.
In any of your threads, did I read a single line of appreciation or "thanks?"
Not one.
This might help your ACTUAL question here:
http://bit.ly/1uJzcBx
