What's that grey wire/tube?
Steve W
There's a light grey wire or tube (I don't see any contacts inside the right-angle rubber boot, so I'm not convinced it's a wire) about the size of #14 wire that threads up the corner of the HVAC box under the hood and originates from inside the cab. Try as I might, I couldn't find anything within its reach that it would connect to.
Where does this go? I'll take a pic later if that would help.
Thanks, all.
Steve
Sounds like a vacuum line. I have one that matches your description for my heater line valve. Its about 2-3mm in diameter and grey. There's several vacuum lines about that size along the firewall for everything from the EGR solenoid to HVAC operation.
Thanks, James - I've suspected as much. Now I have to find out where it's supposed to connect! I have noticed erratic behavior from my heat/ac controls, so this may be the root cause.
Steve
