predator
i was just wondering if there was any way to diagnose a bad fuel pump, are there any characteristics of it??
91 explorer 4wd 4.0 5spd
take the fuel filter off and crank the motor over ,if fuel comes out of the line then your pump is doin its job.
, if you think its the filter take it off and try to blow through it, blow the same way the gas flows through it, there should be an arrow on the side of the filter.
What is the fuel pressure supposed to be on a 93 4.0 4x4? I get a reading with KOEO @32psi and KOER @ 32-31psi and KOER RPM @ 2000 29psi. Truck does not seem to hesitate, and seems to handle hard takeoffs well (I usually drive easy and slow, but tried it to see). Had her up to 80 for 2 miles and no problems.
