Hick
4X4 seems to be inop. When I push dash button(4x4) light on switch,dash both come on and I can hear a half second "click" at the motor, no front engagement? I tested this by dumping the clutch and looking at thr ground for 4 "patches", is this a VALID TEST???? When I push the 4x4 button the second time it does NOT turn off. If I turn off the truck and restart it the 4x4 shuts off. Low range button does not respond to being pushed. Computer(behind seat) passes the self test. I thought the motor would have made more of a noise,or is just a "click" what I should be hearing??? Anyhow,just for the fun of it? I completely remove to motor,again ,click. Manually engaged transfer case at the selector shaft. It still does not SEEM to be in 4x4??(see test above) Is the front pumpkin torque controlled?? or do I,as I suspect a hub issue? If I understand how this system works, you push the button,that tells the computer to tell the motor to turn the shaft, front driveshaft spins pinion, which forces the differential and axles apart, pushing the axles into the hub splines??? Yes? Am I missing something? Will it funtion properly by just flipping the shaft to the right spot?
