what transfer case
scotiascrapiron
Hampton S.C.
what transfer case was normally behind a c6 trans (??? year) and will it bolt to a c4??? I've heard that all ford transfer case bolt patterns are the same. While I could maybe have someones attention I got another question: what is the gear ratio in a 1354 electric t/c out of a 91 Explorer ???:icon_confused:
no not all ford tcases are the same or you would see everyone running the f150 tcases
RBV cases (all) have a 2.48:1 low range ratio.
The RBV case's 5-bolt pattern is unique to RBVs.
dang, so even tho the t/c was on a c5 that came from under a bronco 2,the t/c off of the c6 will NOT fit, right?
correct you need an adapter plate to make it bolt to a c6
or take the 302 out(it's kinda tired anyway) and go big block:icon_surprised:. I already have the 44,9 inch, c6 and t/c. Seems a waste to just let it sit there. Thanks all for the info.
yep i cant think what the borg warner f150 tcase is
