what trans fluid to use
87Jeffrey
I'm swichting from my junk A4LD to a manual transmission to A manual. my Dad told me that that I would need to use Auto trans fluid. and check the bands. My neighor told me hat a maual has no band and that you use gear oil. because if you use auto you will F--- the thing up. I was woundering who to believe.
I am yet to see a manual ranger transmission that has bands.
oh I sorry I'm going stang 2.3 T5. My neigbor told me that no manual has bands.
ok That is what I thought My dad does not want me to fix it. Because The A4LD was rebuilt 4 times. He thinks it is a waste of time. But this was my grandpa truck. we are not ford people.althrough I will not let it go this easly.
T5 will be awesome. I too am on my 4th a4ld. Added a second cooler to my a4ld a shift kit and a temp gauge and so far it's held up well.
Most manual transmissions Now a days Use Automatic trans fluid and have NO bands. None of them do.
Your neighbor is correct about the bands but is INCORRECT about the fluid. Use automatic trans fluid.
ok so when did they go from gear oil to ATF
Oops I missed the part where you said you're using a T5. I thought you were using an M5OD. Honestly I don't know what kind of fluid a T5 uses, but it's very likely it uses ATF, so make sure before you fill it.
ok I'v got a stang friend I'll talk to him then to see. Only he has 302 bored .30 over
