what tranny and cluch do i have?
2.8broncoII
i bought an 88 ranger 2wd 5 speed and it will need a tranny because its hard to shift to 5th gear and it doesnt have reverse(just wont go in) does anyone know what trans this is so i can go get one from a bone yard?
Another question the cluch seems to be at the end of the road. I recently bought a cluch for my 85 bronco 2 2.8 4 speed 4x4... will that clutch work behind the 2.9 too?
http://www.therangerstation.com/tech_library/AllanD_transguide.htm
i assume that since you are asking about the 2.8 and 2.9 clutch compatitbility then the 2wd has a 2.9 in it.
copy and paste from the tech library link.
'88-92 Rangers 2wd equipped with the 2.9 engine there were both
1)Mazda built M5OD-R1 (2wd Version)
2)Mitsubishi FM132 (2.9 2wd ONLY)
i forget what physical characteristics can be used to tell them apart. look at the tranny, it may have a tag on it somewhere that will tell you the manufacturer.
ahhh ok i see ill check it out... any other input on the no reverse and hard into 5th thing?
update! i have 5th and reverse working now. I just need to know if the clutch from the b2 will work in it or not..... plus my through out bearing is going.
