what to do with ABS
np205
Port Angeles, WA
I'm just curious what people did with there ABS when they put in strait axles???? Looking to do some work and wanting to know what the options are.
Thanks,
Owen
I pulled the ABS controller out from under the hood. Im running all new lines straight from the master.
I pulled my ABS fuses under my hood, no more ABS probs, full brakes and they lock up when I want them too:headbang:
Sounds good. Was wondering about a proportioning valve mabey. I like the idea of taking out the controller.
I got a 96, and I haven't had any probs with mine, I pull a trailer often, going downhill if I get on my brakes hard enough, the rear will lock up just a little, on flat ground all four lock up, you should be okay...
cool, sounds good. Now I just need to build my shop to start working.
np205, where did you get your programmer and what'd it run you?? This is what my rig looks like, so I know you'll have no probs with your brakes
SVT
Same color as mine.
I got my tuner from Bama Chips.
I think it was about 375.00
