swampdaddy14
i've got plenty to pick from for my SAS but i don't know which one would be easiest and the strongest to swap in. I have been thinking a dana 35?
The Dana35 never came as a solid front axle.
Some people use Dana 30s from a Jeep Cherokee XJ (maybe that's what you meant?). I think it's a bit too light-duty of an axle if your truck is a Supercab, however it's likely to work better for you if you have a regular cab truck.
For a Supercab truck I suggest a D44 of some sort. Ones from a '80s Jeep Wagoneer are popular, as are ones from F-150s (either left full-width, or narrowed down 6").
Search around some, this has been covered a lot here already.
Moved to non-RBV axles
would it work if i put front and rear non shortened dana 44s? I think it would look badass
so heres what ive decided to do
Talked to my buddy who owns a junkyard and he is setting me up with jeep wagoneer front rear axles and the suspension (coilover)
using the ranger steering box (not sure if that will work)
also im not sure about the lug pattern how hard is that to swap out?
will this work?
