What size pipe and what muffler???
marvilusone
Kannapolis, NC
I just picked up a 1985 Ranger with the 2.3L and a 5sp. Ive got an Accel oil on it and an homebrew K&N intake. This is going to be a DD for the most part. What I'm wanting to find out is what size pipe should I run for the exhaust and what kind of muffler will give it a little tone but not anything too loud that will resonate inside? I'm looking to stay as cost effective on this as possible. I won't be running a cat either. So far I'm thinking about 2.5 inch pipe with a Cherrybomb brand Turbo muffler.
2.5 is a little much..i use 2.25 on my 4.0L. It's plenty. I recommened not going over 2.25 otherwise your exhaust velocity will slow down causing the gases behind to start pushing again...like backpressure..sounds weird but it's true. Cherrybomb turbo is a good idea. but i'd go with a flowmaster 50 or 60 series.
theres no advantage to removing the cat converter......you will not gain power or mileage....not to mention its a hefty fine if the feds find you (there may be local fines on top of that, depending on your area).
i concur with dean on pipe size...2.5 is way too big for a 4 banger....even 2.25 is going to move your power curve up a lot. i'd stick with 2" if it were me, to keep the power in the RPM range where you use it most. if you dont want it to resonate, make sure you exit as far back and out from under the vehicle as possible (no dumps under the cab). mendral bends are your friend....as is a packed muffler.
mine has stock exhause manifolds and stock double cat converter with cherrybombs new muffled muffler..
cherry bomb came out with a new muffler that isnt straight threw.. i have it on my truck and i actually noticed a little more top end.. DEAD SERIOUS
check a local muff shop and see if they carry it
i can make a sound clip if ya want
stock 2.0 inch to the new 2.25 inch slip over
i am in the middle of doing this:
2.5" through a Flowmaster super 44 series, which dumps into a 90 degree mandrel bent 2.5" pipe that dumps before my tire..always wanted to do this..Flowmaster mufflers are great for their price and don't go any bigger than 2.5" on a 4 cyl like mine. Had a turbo, not too bad of a muffler.
What Muffler?
I have an '85 w/4.0. I only run the cat, no muffler with a short pipe that turns out a foot in front of the r/rear wheel with a chrome end on it. In fact I have the y pipe to end off the truck right now, I do use headers but stock exhaust is practically the same.
I used the existing hangers on the frame and it is a clean set up that sounds pretty good. Not too loud but friends tell me they know when I'm coming as the tone is distinctive or one of a kind for here. And here is a rural N Central Kansas farm town that has plenty of diversity on trucks, mostly full sized, but nobody chides me on my Ranger.
It has proved itself here,its no beauty queen and I'm proud of it.
But IMHO headers,a cat and short but pro done pipe not only improves low end performance, it just looks good. Like a truck should.
BTW a two full size fords have looked at my setup and did the same, its responsible and economical at the same time.
I am running a 2" pipe with a cherry bomb brand turbo muffler. I have a before tire exit. Works pretty good.
I wouldn't ever go above a 2" pipe. I actually came back down from 2.25 when I redid my exhaust.
Keep the cat if you can.
is it just me or does 2.5 inch just look to big i went 2.25 on my 4.0 with one cherry bomb ans a turn down after the rear axle sound bitchen
lest you forget
even though you change airflow in or out of a computer controled eng, the computer will adjust for any change you make and and percieved condition that arrises normally on its own.
Just a thought to keep in mind...
