What manual transfercases bolt up
Exenos
Ontario
Is there another manual transference that bolts up to a 4wd m5od? 1354m's aren't exactly easy to find and I don't want to deal with the wiring for a 1354e during the 4wd swap.
A 1350 will bolt up if you don't mind the slip-yoke type front output... Unfortunately there isn't anything else besides the (pricy) Atlas II that will bolt up to the unique RBV 5-bolt mounting flange.
Did you try looking for a 1354 in your area on www.car-part.com?
Darn, I thought so. Theres nothing on car part withing 400km of me. Is the output shaft unique as well? I don't mind making an adapter plate.
Hmm, I like that. Might have to see what I can do to sort out something similar. I have a 1354e to play around with anyways.
