C-Bear
- May 2, 2012
- Automatic
Hey everyone, I've got a 98' ranger that's having a charging problem. I think I've narrowed it down to being a short or something on the light green and red wire that runs from the alternator to the battery light symbol on the dash. I've also heard that it "turns on" the alternator. I've been tracing that wire and see that it runs from the alternator, to the pcm, and then from the pcm to the clip that plugs into the dash for the battery light. However while searching down around under the steering wheel; theirs a light green and red wire that goes to this light post and is attached via a clip.
It sits right behind the emergency brake and has a little spring loaded thing on it, but I can't figure out what any of its for, theirs no other wires attached to it.
I'll try my best to explain it exactly, I can't figure out this uploading pictures thing.
It's a white plastic clip that's attached with a gold screw, its got a little spring loaded pin that sits on top and when you push it down it just comes out of the bottom, the wire is attached right behind it and it is connected with a small clip.
It is really small and literally right behind the emergency brake, kinda right in the corner.
Please let me know!
Please let me know!
