What is this called?
Jraymer360
Belleville, MI
The rigged looking plastic thing that holds onto the nipple-type thingy. i've tried searching up shifter linkage and i can't find anything...it's what puts the trans into gear from the column, it's right at the firewall...kinda looks like the PO rigged it on, as it's being held on with 2 Zip ties. it's worn out and won't stay on anymore! can i replace that or do i have to replace the whole cable or what?
Ball socket?
I am going to bet it is part of the cable...
It's called a shifter cable. It's only available as part of a shifter cable. You will need a new shifter cable.
They aren't that hard to replace. Floor shifter setups are a lot harder because the dash gets in the way.
less of the difficulty of the work, but the price of the cable verses the price of just the end. i am poor at the moment.
zipties are your friends. I am not responsible for anything that occurs if said statement is used. But I have encountered several that were ziptied in place (Happens when you work for used car lots) Not an ideal fix but could get you around for a bit.
The thing is.zip tied to the cable! Im gonna pull off the cable and see if i can just get another enf from the hardware store if i dont have the funds for a new one
Why don't you have an emergency fund?
