what is needed for a dana 30 swap??
Tyler Brisson
i was wondering what would be needed to do a dana 30 swap? like whats the best dana 30 i could use out of a jeep? do i need new coil buckets, radious arms and or radious arm cross member? and how much labor and what labor is required to do this ? let me know thanks
Well all depends on what your going to be using your truck for. Theres alot to consider when doing something like this such as what are you going to be using your truck for, tire size, your fab skills, etc..... Theres no define answer to this but reading build threads should help you out and along with this link from our tech. library.
http://therangerstation.com/tech_library/Dana30.htm
Im going to be running coils when I do mine, told its alot better ride. Im also going to be using longarms too for my sawp (ya I paid the money for them $$$$) but in th end I see it as its worth it.
it is gunna be a dd and a weekend warrior so it does need to be pretty reliable and its going under a 93 extra cab if that helps and runnin 33"s for now. but is there anything i need to get to get it bolted in there???
For the love of all things reliable....dont swap in a D30......d44's are cheap.....come on....
