What has everyone else done to prevent Hurst leak
Airmaster
South Florida
2013
I got the Hurst short throw in there and I am definitely warming up to it.
I have two issues.
One, I need to adjust the height of the shifter, it is far too low for me to shift comfortably. I have two options here: Contact Summit and/or Hurst and request a longer stick, or make an adapter to get it to fit right.
The second issue is that there is a horrible leak between the shifter and the gasket. This shitty gasket/seal is worthless! What have you guys done to keep it from leaking, I've searched the forums and the only thing I find is to buy gasket paper and throw rtv on it.... this doesn't solve the problem of excessive pressure in the case.... Are there any negatives to having a build up of pressure in the transmission?
Once I attend these issues I think I will be madly in love. All relationships start off with problems, those are the ones that sometimes have the closest bonds. That's where I want to be with my shifter, happy and as one. :icon_twisted:
P.S. I wanted to add, I will be contacting both Summit and Hurst during the week and I will definitely post my feedback to what they tell me. :icon_thumby:
I also want to know what gasket paper I should use. What type of material should i select?
you didn't fill the trans all the way to the top, did you?
