what gears do i have?
dru
Pacific
where is the inspection cover to locate the type of gearing i have?
already saw it. it doesnt explain where the inspection cover is located.
what inspection cover? theres a sticker on the drivers side door that has an axle ID code, and theres a tag on the cover on the rear differential that you can decode to know what gears you have.
"What axle do you have now?
You can identify which axle you have by the tag attached to the inspection cover. "
This is a quote from the thread link above.
they dont identify the location of the "tag attached to the inspection cover" I assume its the "tag on the cover on the rear differential" that you speak of.
ill take a look at it.
thanks
Kunar,
thanks for pointing me in the right direction. i located the tag on the diff.
