what engine would YOU use
They make around 245hp and 15 psi on pump gas is totally doable. That'll double the stock hp give or take a bit. 21 psi will triple stock power. All assuming the turbo and fuel are right.
Boosting to 14.7psi will double what a motor will make naturally aspirated.. to triple N/A output a motor would need a c-hair under 30lbs.
Good to know that those are stout motors though.. 5cyls are cool just because they're such an odd duck. Didn't GM get the motor from Volvo or something? They do sound pretty wild.
FMS
Amazon lost the FMS one, I ended up ordering a aftermarket one that I think had to come from China. It was down for a month before I got the part to fix it.
Gah, hate waiting for crap like that lol. Do you have a hobby shop close to you? I'm relatively sure the crawler I put that Maisto 2dr bronco body on was an FMS.. or mabey it was an ECX? Relatively sure they're pretty much identical either way.. "white box" trucks more or less.
And no engine sounds more like an electric air compressor than a rotary at idle...
The Mazda B series had the REPU that came with a 13B from the factory for a few years while they were also being rebadged as the Ford Courier. I don't think the factory ever put the rotary in the Ford, but that would probably be a bolt in swap for a Courier if you could find a wrecked REPU. And I don't remember which channel it was but I saw a YouTube video of a 12A swapped Ranger a few years ago.
Yeah.. stock idle honestly doesn't sound too cool lol. Anything that's been ported though.. either a street port or a race port.. idle sounds wayyy gnarlier.
Pretty close to a mildly juiced up 2 stroke snowmobile imo.. and that's a sound that could put me to sleep 🤗 I really miss riding sleds. Shame we don't get enough snow up here to make owning one worth it anymore..
Just a Hobbytown. It uses a smaller than normal servo though.
Yeah, oops, I knew what I meant, apparently you did too :)
I do get to play with some cool stuff here and there that I wouldn't pay for... like the 600hp LT4, we're working on a big block around the 9L range, we have this compressor engine that's technically a 14.6L but it's only running on half so it's a 7.3L 4 cylinder...
Not quite exactly how the math works out with volumetric efficiency, but close enough for bragging rights...
not big into forced induction but 21psi sounds like a lot for a engine that size i could definetly be wrong being that as i said i dont know a lot about it would love to learn though
