bronco2billy
My 97 Ranger 2.3 runs like crap when started then runs a little better when up to operating temp.Actron scanner says no trouble codes found.At idle live data shows this,ABST TPS %16.5 /RPM..796-836/ CALC LOAD%..68.6 /MAF lb/m .48-.51 /coolant temp..194 /IAT 194 DEG F. /IGN ADV. 9.5-11 /ST FTRM1 % -3.1 to +.8 /LT FTRM1 % 9.5 to 10.5 /FUEL SYS 1 CLOSED /FUEL SYS 2 N/A /O2S11 volts .015 to .620 /ST FTRM11 % -2.3 to 1.6 /O2S12 volts .060 to.705 /OBD2 STAT..CA. Can anybody tell me if these readings are within spec. or are some out of whack.I have already changed all plugs with right gaps(old ones were set to .055)new wires (old ones didn't have #1 wire on spark plug the whole way,and ended up arcing the metal cap out of the boot on intake side)cleaned MAF sensor with MAF sensor spray,cleaned IAC with carb cleaner.new air filter,look like there is a new fuel filter on it,new Evap purge valve(threw code with old one but now it doesn't).Any help would be greatly appreciated.Thanks.
