RedNeckRanger
- Oct 2, 2007
I've got a 1994 Mazda B4000 (Ford Ranger) with a 4.0L OHV, and recently had to replace the sensor only (not the complete synchronizer assembly) due to a rough idle, misfire and DTC. I had to go with a used part because I couldn't afford a new or reman. unit and now my truck cranks but won't start. I have zero fuel pressure at the fuel rail and can press in the schraeder valve and not a drop of fuel comes out. I know that the synchronizer controls ignition timing and injector firing, but does it also control fuel pump operation? When I turn the key on I hear the sound that the fuel pump makes when it's normally priming but get no fuel when cranking. I can't seem to find the answer to this in my repair manuals or online. Thanks in advance.
