What do you guys think?
Fordisthebest30
Firefighter
EMT / Paramedic
Alaska
1989
Ok, so first off ive been having some idling issues. I thought it was the IAC or MAF. So I cleaned both really good with MAF sensor (MAF Cleaner) and Carb and brake cleaner (IAC). Both didn't work. I then moved onto the coolant and engine temp sensors because my sensors weren't operating correctly. I thought it could be that because I thought the coolant sensor was sending the wrong message to the PCM.
I went through and tightened up all the fittings on the air intake and and checked the air filter. They all have seemed to help a little bit but the idle is still rough.
I did notice some moisture in the throttle body along with soote
Any thoughts?
Try getting rid of that moisture...
Cars don't like water
ok. I have no clue if its condensation or if theres a leak somewhere in the air intake that would cause it. last time I pulled it apart (week ago) it didn't have it. maybe it's from all the ice fog we have had lately
