What did YOU do today?
Stop snorting acid
Considering this is what I look like now.. you may be onto something with that.
Don't gotta worry about no boogies anymore though so... Pros and cons I guess šŸ¤·šŸ»ā€ā™€ļø
We had to take off last night at 11pm to go tow the 03 wrangler home from refugio, a bit over an hour drive at normal speeds.
The u-joint straps and bolts were missing and the u-joint caps had evacuated somewhere after the jeep's shaking started
So we drove up and had to tow strap it home. Got home at 3am because we towed at 40mph tops and usually 35mph.
And my phone flew out of the truck right when we left and I found it the next morning in 7 or 8 pieces on the side of the highway. So I have a new phone now :(
First evening I've been able to spend in my shop since like last Friday... took it easy and worked on the loader valve I bought for my tractor a couple weeks ago, annoyingly the threads are BSP on the dumb thing but it was $75 so pretty much disposable in loader valve land... so I was going to run a tap down the ones close to 1/2" NPT and 3/8" NPT but the tap bottomed out on the ones close to 1/2" as is so they're fine, the smaller ones I ran a tap down... I'd acquired some steel bushings to get to 3/8" NPT and 1/4" NPT since that's what my hoses are so I drove those in with some pipe dope. I'm 99% sure this will work fine and leak less than what I have now...
The other day I ordered a slew of belts for spares for the riding mower and the tractor finish mower along with a pack of idlers for that guy too so soon I'll put a new belt on that and some new idlers. Tomorrow night I hope to put some of the tools away from the Camry project but I have to clean them up first, wasn't in the mood tonight...
Mine has an E-series shift stub and a custom bent up shifter out of 5/8ā€ rebar, lol. Kinda would like to do the same thing to the ZF5 in my F-350
I dont like to brag but back in my younger days i could shift those old 4speed granny boxes faster then alot of guys could shift their mustangs.
Damnit...youre making me want another one lol. How can i adapt a T18 to a 2.9?
My Choptop has a stupid long 5/8ā€ rebar shifter on the FM-146, lol
Rescued a Land Rover.
I had just gotten home from my exercise session and sat down to rest for a minute. Looked at Facebook and saw a cry for help from someone who frequents out local ORV park. Stuck in Sumter National Forest. Anyone close by with a winch? I replied that I was an hour away (second closest person in the group). After 10-15 minutes, there weren't many communications. I deduced that he was in bad cell service. So I headed out, knowing full well that the controller and wiring harness for my transfer case are under a table in my living room. Oh, well. If I need 4x4, I'll install my shiftster. We've been in a drought this spring. How bad could it be? How did he find enough mud to get stuck in?
Well, he found the one mud hole and got it dug in deep. Stock Land Rover on what I would consider street tires, although they are probably wimpy all-terrains.
I went around him and set up on a high point so my winch would be lifting as it pulled. Worked like a charm. Soon, I was back at the creek crossing letting Livvy cool off in the water. All done. At least he didn't have to get pulled out by a Jeep.
he WAS in that mess in the left.
That's impressively bad picking a line there.
Trip went well last weekend. I don't THINK I broke anything, even though we hit one 300 road. Seriously thought I was gonna be in trouble when I saw @Robert Mangrum dart to the side. Ended up in a pretty serious set of ruts. 4low pulled right out though.
Couple pics from the day:
Since I've been busy working. 62.25 hours this week. Next week will be slower. Then the week after we should be busier due to some new molds, IF the process techs can figure out how to make them work. They are actually too large for our plant. One is 62,000lbs. We only have a 25ton crane. It has to be set in halves. Then it's designed for a 4500ton press and our largest machine 2100 tons.
Seasoning up my little flat top. Bout time seeing i bought it last year.
It's a bit smokey... I had also just lit the charcoal chimney. Not to mention... it's pretty hot today... my kitchen on the deck is pretty damn hot.
I spent the week chipping away at my workshop project. Unfortunately it’s taking longer than anticipated. But it’s going to be really nice. I have most of the frame put together, still have to do some reinforcement and finishing and stuff.
