What did YOU do today?
I got my own TV show!
Well, among other things that got half-accomplished today, I finally got the fill plug out of the drain plug on the transmission on mom’s 02 Explorer. It’s an Allen key thing and of course it stripped so today I managed to wedge an easy-out in it after a couple failed attempts and get it out. I have something to say to the engineer that thought this was better than having a dipstick, by the way…
Anyway, I was hoping the fluid would be low. Unfortunately, it appears to be at the correct level. Which tells me that most likely the 1st/reverse servo gasket/O-rings is likely the problem and it could stand a band adjustment. Also unfortunately the tap sockets I bought apparently don’t fit to adjust these bands so I guess I have to look for the correct socket when I go looking for the other parts. I really didn’t want to have to deal with this right now because I still have to deal with the transmission on my green Ranger.
We all know women can't drive.
Most women actually end up turning into good drivers...
So if you're a good driver... Make sure you keep an eye out for turning women.
Tonight I exterminated some pest birds in the cherry trees then cleaned the shop to make room for two Camry's to make one out of this weekend if at all possible...
If you don't currently have the '95-97 beam setup I think you would be better off keeping the new beams even if they aren't straight, the steering stops changed with the new setup. Straightening the bottom is annoyingly easy, last time I did mine was with a come a long to another vehicle hooked to the middle bottom of the drivers side beam...
I currently have a 93 or 94 beam with 95+ knuckles. (No steering stops.) I think these would be fine, but after seeing the damage to the underside of the truck I pulled it from. The transfer case skid plate was so curved it almost looked lit it was installed upside down. The transmission crossmember had a definite curve to it. Couple with the dent on the bottom of the beams. I wish I knew an easy way to check them for straightness. I'd hate to build up the new axle then realize it's bent after install.
Patriotic concert entitled "Happy Birthday, America" by the Greenville Concert Band with guest trumpeter, Dr. Buddy Deshler.
I'd fit in good with all those boomers
So far tonight I've gotten both Camry's in the shop, plenty of room up front so I don't have to find places to stash more junk elsewhere... I even got both hoods off and continued the tinkering, here shortly I'll take the shop vac to both and get the spiders and mouse presents removed to get started... probably start draining coolant out of both. A coworker is coming over tomorrow morning so we can hopefully get things moving on the engine/trans swap...
Gave my truck a little work to do...
Springs handled it well.
Frigged around with the dirt bike I brought home as a project last year.. was kinda figuring it was smoked even when I picked it up but nah.. seem to have gotten lucky (so far anyways)
Adjusted the valves.. fired right up and idled well 👍🏻 awesome, it didn't wanna start for shit OR idle when I got it so..
Took it for a rip.. running stronger than ever.. buuut started to run like a bag again after a mile or so 👎🏻 boooo.
Get home.. take the side cover of the air box off.. and at least 8 ounces of gas come pouring out 🫠🫠
So.. carb disassembly & inspection next time I want to deal with hands that smell like gas for 2 days 😑 I really hate carbs. At least it's a real keihin and not some china crap.
Breakthrough update:
Yanked the carb the other day.. started digging into it today.
Float level was waaaaayyyyyy too high (much like the kid I got the bike from lol) It's supposed to be 14mm.. somehow it was a smidge UNDER 10mm.. reset that just now. There was a little crud stuck to the rubber tip on the float needle as well.. AND a nail shoved up the bowl overflow hose with a zip tie wrapped around it 🤦🏻‍♀️ lol..
So yeah.. no wonder it wanted to fill the air box with gas while it was running. This new generation of baked teenager seems to be much less capable than baked teenagers of old.. so that's unfortunate.. but.. their inabilities to do basic troubleshooting wound up getting me a few year old dirtbike for basically free so 🤷🏻‍♀️ their loss. Thanks kid 👍🏻
Kawasaki also has these jetted way too lean.. especially on the idle circuit, they did it to meet emissions goals. Everyone complains about how cold blooded & hard to start they are... So gonna order a couple upsized jets from Lord Bezos and grab a can of cleaner.. hopefully by the end of the week it'll be running as strong as a 3 year old bike should 🤞🏻
