What did YOU do today?
I packed for deer camp and loaded most of it in the truck. Since it is a drill weekend, I can't load the rifle and ammunition. So, I'll pick that up and my pistol from the house after drill. I also have to grocery shop before I head up to the camp. I'll be gone for the week and signal is spotty. So, I probably won't be on much.
Don’t worry. We’ll talk about you.
That is to be expected and a given.
Apparently, quite a bit of that is happening at the base as well. It is surprising as far as the number of people asking about me retiring.
Turns out I made one of my lower ribs mad yesterday doing something... lame... I'll power through but it's sure annoying.
question of the day: are you parked there because of the Spa, or H & R block?:dunno:
Spa treatments can’t be taxing…
I have no idea where that was, but the truck was clean and it was a good spot for a picture
Tentatively sold POS I'm trying to unload (it works and I am honest with the buyers, I just don't like it).
Put cam bolts into truck so I can get an alignment tomorrow and finish the longest front suspension job ever.
@ Home, it's raining, and I have the #LatestCrud.
Trying not to choke myself on post-nasal drip, playing an 11yo game (still buggy even in the Anniversary Edition), and trying to figure out how to get my GMRS Badge now that I'm licensed [got it!].
Changed the nasty burnt power steering fluid in the '97 Ranger and rotated it's tires today, steers way better so far, going to have to do it again at least once to get all that old fluid out, annoying that I can't get a hose down in the reservoir to suck it out, no good way to cleanly drain it... ended up pulling the pulley so I could get it loose so the return could be pointed up then put a suction pump on and empty it... next time I'll just not pull it into the shop and try to put the pump hose on with losing as little fluid as I can...
Also worked on getting the rest of the pile of junk in the burn pit burnt, wet leaves don't want to... and dusted the walls in the shop office so it's more ready for texture.
New desk in my computer room.
I know it's raw 2x4 but its comfortable. Plenty of room underneath for my heater and storage ottoman thing. And it's 74x28 of desk space.
I've got to work on rearranging some other things in the room.
My last post, Sunday morning, I'd just discovered my water heater had been leaking for an while. Well after resting for a bit I went to the store to buy some supplies and do a little triage.
When the water heater was installed a catch pan was placed beneath it. Idea being that since I was leaving the panel off of the cubby at the time, I'd notice the wet if it developed a leak. As such I never bothered with installing a drain for the pan, still better than no pan at all like when I got the place. Then when I installed the panel I put in the water alarm to warn me, the one that didn't sound (more on that in a bit). Got PCV supplies to add a pan drain, and some blocks to space the heater up off the pan a bit. Got back home drained the heater and proceeded to start demoing the face of the cabinet. I'm pretty sure that the closet is going bye bye. If not gone completely I'm going to be reworking it some adding a proper door, and maybe a closet above to utalize the wasted 4-5' of space between the heater and ceiling, and it's an electric heater so no combustion issues. Last thing for the day was to pull the water heater out of the hole, and put a fan blowing on the space to dry it out some.
Today after work got under the house and started digginG in to see what I could do. First order of business was strip away the under floor insulation under the water heater location to see where I could safely drill through for the pan drain. Carried the insulation removal clear across to under the kitchen island where another of the soft spots is. You can clearly see that the floor will have to be replaced there. Got a bot of disappointment about the construction of the house. In my parent's house, there is two layers of plywood in the subfloor. This place only appears to have a single 3/4 inch sheet, and I didn't pay enough attention to notice if it was plywood or OSB. I would really prefer it if it had two, and it probably would have resulted in less work to repair. The do it right side of me says go back with double layer, unfortunately that would require tearing out all cabinets and walls to lay it in, I'm hoping that I won't have to remove any walls and maybe only one cabinet. I suppose I could just cut it around the walls, but I'd still have
uneven floors through the house. If I knew I were staying here I'd do it and eventually do the whole house (and new cabinets too), but was already thinking about moving closer to family and work and really gos serious about it since dad passed.
Anyhow, I got the pan drain installed, water heater set back into place and hooked back up. It's still going to leak, but now it'll drain outside and I've got hot water while I'm figuring things out. Next step getting more of the house cleaned up and rearranged so I can cut back the linoleum and see just how much I have to replace.
It's not by any chance a Bethesda title is it? It certainly sounds like one.
It works, and if I'm being honest, probably works out better than any computer desk I've found in a store. I've bought or been given a couple of desks over the years. They never seem to be laid out right for the equipment and/or the room. If I knew I were staying here I'd build one (probably similar to yours) for my computer room and put a free sign on this big Office Depot L desk.
Today I upgraded to a locking tailgate... I definitely didn't just pull a little too hard on the handle and break the plastic on one side so it wont open with my tonneau cover secured so I'm locked out...
