- May 15, 2020
- Age
- 71
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
Yes, the originals were some sort of semi-press fit because originally they had a metal clip to help hold them in, as I recall. The clips are long gone. But I’m pretty sure they were there at one point. Dad’s tractor that I borrowed a link didn’t have the same exact bends and the balls were just press fit, no clips. Since it was a newer tractor I had thought perhaps it was an improved design but no, it does not appear to be entirely interchangeable.
I had thought about doing heims on both ends but I wasn’t sure if that would work since these ball ends have more movement so I started with those. Plus the ball ends I got were for an MTD tractor (most small lawn/garden tractors like MTD, Craftsman, etc. were manufactured by AYP which is American Yard Products, so the theory I had was perhaps they should work?). Anyway, a heim is like $20-30 depending on the size and how rust resistant it is. These ball ends were $8 each. I think perhaps a heim at the steering gear end could be easily set up to limit motion in a certain direction but the design of the ball ends makes limiting motion more difficult.
The floppiness is only half of the problem, the other half is that the rod is flexing too much. There’s not as much room to gusset it as I thought originally and the bends don’t seem to be the problem as much as the long section with the one small bend, that actually bows the opposite direction of the bend…
OK, I’m embarrassed, I’m a ChemE and I don’t remember how to harden a piece of steel. The piece of steel you fabricated, is it more flexible than the piece of steel from the original piece? Could that be one of the issues? Several thoughts come to mind, what about heating the whole thing up with the torch and then quenching it in water or in vinegar, I don’t remember which would stiffen it considerably. Another thought is bathing it in caustic, which I believe is supposed to harden it, but I haven’t done things like that in years and years and we need somebody else to jump in. That’s more familiar with what’s going on today to harden it up. If you could harden it up, and use a sleeve or such to limit the flexibility of the end balls, you might have a good fix on your hands.
Edit: I fixed Mr. Ambien’s typos
