- Sep 17, 2023
- South carolina
- 4.0 V6
- Automatic
Installed a ladder rack.
Good luck actually getting that product. Warn stopped making hubs for the ford d35 axles and all the small guys haven't updated their websites yet. I tried three places including Summit and they all gave me my money back.
Once I verify my auto hubs are good working I'll do a writeup on how to give them a tune up.
Yeah, rust really sucks. I love living here other than having to deal with serious rust problems. And the stupid government, but that’s it’s whole own issue….I don't have the patience for the rust you guys deal with, conveniently I normally just have to use my fabrication tools for fabrication... not repairs that shouldn't have to happen...
I get nervous when I'm down to one running vehicle and it needs attention.Ran the rest of the gas out of the Strangler. Next week, I hope to finish the work I started earlier in the year. It sucks have to do so much work on my daily rider. If I F something up, I walk or borrow a car.
I have 7 and only my daily is running and barely running at that. I just can't afford all the extra vehicles. I'm going to start fixing and selling next year. I need money for a project I may be picking up over the next couple of weeks.I get nervous when I'm down to one running vehicle and it needs attention.
Installed new front rotors, bearings, and brake pads. One of the old outer bearings was just starting to show signs of future failure after only about 25K miles (fine scratches on all the rollers), and I had been hearing faint bearing noise. The other outer looked all right.
Used NAPA parts and Red Line synthetic + moly grease. Made makeshift bearing packers using small containers, the aluminum discs from a bearing press set, and a C-clamp to force grease between the rollers.
Noticeably quieter when it was done. I wanted to take care of this before springing for a set of new tires and an alignment in the near future.
The old bearings had been very slightly loose after I installed them, and I had adjusted that after catching it several thousand miles later. This might have been the source of the problem, along with packing grease into them by hand the old-fashioned way. Live and learn. I did not pop off the old seals to look at the inner bearings.
Did have enough rust on the old passenger-side rotor to force use of a 3–pound maul on the inside of the tires to tap the wheel loose. The rust was on the hub portion, not behind the wheel.
Also checked the differential lube using the fill hole. All was well and it wouldn't take any.
I have a cool whip container that I mix general purpose grease and used motor oil to a paintable mix with a 1” brush that I use much the same. I’ve had to use multiple hits on the tire with a 16# sledge before to get a tire loose (only hit the tire, smashing on the rim will damage it)One trick I learned that has worked reliably for making sure the wheel does not stick to the hub, or for the drum/rotor to the hub on vehicles that don’t have the hub integrated into the rotor, is to spray the hub face with fluid film. I’ve never had a problem with the wheel sticking after I started doing that and most times, there is enough left that reapplication isn’t needed.
I was in that boat not too long ago, due to a long series of unfortunate events. Not completely out of the woods yet, but I now have three that run and drive. Still have to squash a bunch of bugs with the one (green Ranger), but it does what it’s supposed to and all the important stuff is new. Choptop still needs the gas tank replaced (I have a new one already) and the front axle needs some issues resolved, but it now runs and drives. F-150 is what I was down to and it needs a major overhaul badly, but now that I’m not using it as a DD, I should be able to limp it along a bit. It’s been behaving much better since it’s been pulled from DD use. I’m getting a newly used frame and cab for it in a few weeks, but probably won’t start on that till next year.I have 7 and only my daily is running and barely running at that. I just can't afford all the extra vehicles. I'm going to start fixing and selling next year. I need money for a project I may be picking up over the next couple of weeks.
