what controls the spark advance?
dwhite
Lemoore, ca
I timed mine yesterday and i pulled the little plug disconnecting the spark advance while i timed it. well when i pluged it back in, and let it get to operating temp. the advance wont bring the timing back down to what i timed it at. and when i rev up the motor it only makes the timing worse?
anyone have any ideas? Thank you/.
So you set the timing to 10* with the SPOUT out and then plugged it back in and is went up around 20-30*? Sounds like it's working normal to me, it's not supposed to return to the base line timing.. BTW the computer controls the timing when the spout connector is plugged in.
X2...........................:icon_thumby:
