What are the side bulbs in the third brake light?
HankG
Humboldt County, CA
Sorry for the dumb question, but I'm stumped. In the third brake light, the brake light comes on when I hit the brakes, but nothing seems to turn on the two side bulbs. When are they supposed to come on? I've been looking through ALLDATA trying to get an answer, and while the diagram for the third brake light shows three bulbs, it doesn't say a word about the side bulbs, and I can't find anything else under other categories about them.
Assuming you mean the '96 listed beneath your name, and further assuming it's the same as my '97, I'm guessing you mean the cargo lamps (the ones behind the clear lenses)?
Rotate the gauge-dimming knob (the one beside the headlight switch) all the way up- turns on the dome light and cargo lamps.
Thanks. :) They aren't working, but at least I know what they are and that they are a fairly low priority project.
Ford did a weird thing and put cargo lights in some Rangers, but didn't actually wire them in. If you only have 2 wires going to the brake light/cargo lights, it's not wired in and you'll have to run your own wire to a switch. If you have 3 wires, it is wired in and you have a problem with them.
