StupidSheet
- Jul 27, 2011
- Automatic
Will a 99 SOHC engine take the place of a 97 OHV engine? If so will I have to swap over the ECU, wiring harness? Will the trans be the same?
I just want something that will drop in and fire up.
my main concern is if the blocks are the same
It won't do that, which probably isn't what you wanted to hear.
I have HEARD of someone retrofitting an OHV wiring harness and computer to work on a SOHC engine, but he didn't say it ran well. For your daughters truck you would definately want to swap all the electrical.
I was thinking about doing a similar swap from a 98 explorer and decided that it would be a big experiment on some level.
http://www.therangerstation.com/forums/showthread.php?t=8426
In this thread a guy claims that the SOHC bellhousing has extra bolt holts, and that a SOHC trans works on an OHV but not the other way around. I think I had read this somewhere else also, when I was doing research for mine.
Why not just find another OHV? How much do you value your time?
