i am "trying" to install my leveling springs. Im good until i get to the nut that holds the retainer in. be cause of the concave of the retainer i cant get a good grip on the nut with a 1-1/8 wrench.
D'ohUse a 1 1/8 deep socket and several extensions which go all the way through the top of the spring, and to your ratchet.
You could also try to lower or raise that end of the suspension with a jack to compress the spring to get a better angle on the nut. But, if you have 1 1/8" socket, that is easier.
it still has the little factory spacer on top of the lower seat. should i remove that if im going to be using the existing shocks? rs5039. the leveling coils are from skyjacker.If you don't have any spacers under the spring anymore it takes a pretty deep socket.I at least finish it with a wrench lowering and raising like superds.
