Well the tags and stickers are gone
Warren 86 ranger
86 ford ranger 5speed 4x4 the tags and stickers are gone on my diffsso ow do i find out what axles and gear ratios i have?? any help would be appreciated
thank you
Pull the cover off the rear end...... the gear ratio is stamped on the ring gear!!!!
you have to spin both tires at the same speed to do that right unless its a tight posi...
..the ratio is not always directly on the gear....
but rather the number and its divider..
.and you do the math.
thank you everyone i hace a nice little coinedence happened i opened up a little zippered bag i found under the drivers seat it had the diff tags in it soo wooohoo 3.73 gears
^^ you can tell the difference between the 7.5 and 8.8 as well as the d28 and d35 by the outside appearance, but that won't tell you what gears you have inside really. my axles are completely stock looking at them, but inside are my 4.56 gears and a Detroit locker in the rear.
