Chic N Stew
Yup, you heard it, im gonna be putting my 351w in my truck this winter, i hope i will have pics, provided i buy a new camera(got mad at it and threw it, lol)
im so excited
Nodular Iron Crankshaft, deburred and micro polished
Shot peened hardened connecting rods
Power Forged 10 to 1 Flat Top SRP Pistons
Sealed Power Chrome Moly Rings
Heavy Duty Double Roller Dynagear Timing Set
Comp Cams Hydraulic Roller Camshaft
Clevite Street Racing Bearings
Aluminum Fast Burn Edelbrock RPM Heads w/ Port matched intake Runners
2.02 x 1.60 Stainless steel Polished valves, Hardened valve locks chrome moly retainers and High Intensity Valve Springs
Chrome Moly Comp Cam pushrods
1.6 to 1 Crane True Roller Rockers
New Melling Oil pump
Fel-pro Gasket set
New Heavy Duty Harmonic Balancer
New Flexplate for Automatic Trans.
New Polished Oil pan, Alum. Timing cover & Chrome Baffled Valve Covers
Edelbrock Air Gap Dual Plane Intake
Edelbrock 650 cfm 4 barrel Carburetor with electric choke
New High Flow Water pump
New Fuel Pump and fuel lines
Billet Electronic Ignition Distributor & high voltage coil with Vacuum advance
New Champion Spark plugs gapped and installed
8mm Accel Silicone Wires
New Thermostat Housing
Chrome Air Cleaner
PCV Ventilation System
New Fuel Lines and Gas Filter
Ignition Timing Set, Carburetor fully adjusted
im so excited
Fel-pro Gasket set
Chrome Air Cleaner
