Snowboarder7710
- Jul 29, 2009
- Age
- 41
- Rancho Cucamonga, CA
- Automatic
My friend has a 99 ranger 4.0 ohv manual trans 2wd. just recently (3 days ago) the truck just wouldnt start. when he turned the key to start it, there would be a click (like the starter turned once and thats it). so we pulled the starter tonight and he went and bought a new one. put the new one in and reconnected it. we go to start the truck and then "click" and then the entire ignition system died. gauges and everything went dead. turns out the 50 amp fuse that supplies power to the ign popped. we looked into that and the thin wire that activates the solenoid on the starter was rubbing against metal. the new autolite starter was a bit bigger than the motorcraft one that was on there and caused the fuse to pop b/c of the wire contact touching metal. we adjust and fix that and still back to square one. the truck wont start...just a single click.
we pushed the truck down the street and he popped the clutch and the engine turned over and it started.
so here's where we are at:
1) the starter is getting power. i verified it with my multi meter and it was showing 12.56 volts.
2) i know for a fact the thin gauge wire that activates the solenoid is getting power b/c it kept blowing the fuse and when we fixed that it still gets power on crank.
3) the ground wire is good because its bolted directly to the bolt holding the starter to the trans.
only thing i could think of is maybe there's corrosion inside of the wire leading to the starter. it gets voltage but not enough amperage or the voltage possibly drops on crank when there's a load on it.
sorry this is long but i wanted to make sure i got all the info out there. anybody have any suggestions as to what it could be??
thanks
thanks
