I've answered this before and it's a fuel problem more
than a fuel system problem, but the design of the fuel system
is partially responsible.
the common complaint invariably comes from someone with a 1990-94 4.0.
the issue is related to the ammount of butane that the federal government allows to be blended into "winter mix" gasoline.
Butane boils at 0.5degC but boild higher when dissolved in gasoline.
the reason the problem doesn't affect the '95-up 4.0's
is because there is a 1/4" thich thermal isolator between \
the cast aluminum fuel fuel rail and the aluminum lower intake.
the design of the fuel rail in the other engines used in RBV's doesn't
heat the fuel to the same degree because the rails all "float" above
the lower intake.
the other factor is that the ports in the fuel rails are at the highest point of the
rail so while there may be liquid fuel in the rail the top feed end of the injectors
so the inector feed point is "high and dry"
the correction to the problem is to either:
A)replace the fuel railand/or lower intake and add the thermal isolator
B) cycle the key repeatedly in an attempt to pump cool fiuel from the
tank through the rail to collapase the vapor bubble
C) carry a jumper wire to connect the switched terminals of the
fuel pump relay socket and let the fuel pump run for the length of one song on your sound system before attempting to start the engine
BTW, jumpering the relay for 2min and sucessfully starting the engine
is a positive diagnosis for this specific problem.
In case you are wondering, yes I have this problem on my 1993 engine.
Swapping out my lower intake is part of the long list of things I need
to do before I make my next trip to Wyoming.
AD
