Weird Noise
Twister
Omaha, Ne
My truck has started making a strange noise, it use to only make it in gear but has started making it more often and even in park. It only does it at low rpm and when you are driving it doesn't make the noise.
I take it you've been under the truck while it's running to find out what that is? It sounds like it could just be a heat shield on the exhaust. Check every little bit of the exhaust to (hopefully) find it.
Otherwise, it might be something worse..
I have but that was after driving for 30 min, so anything i touched would burn my hand off
I hope it isnt something worse, i seem to have the worst luck with cars.
I figured out it is the muffler, it is very annoying but i don't think it is hurting anything.
