puredreamz
- Nov 13, 2010
- Automatic
What Happen:
I was hooking up a plow light just wanted to see if it worked, found constant power of #3 in fuse panel, wrapped wire around fuse touched power on light. It lite up for 2 secs then stopped, hooked up light to battery and it worked. Put test light on the fuse 3 no power and the fuses werent blown. I dont have a proper fuse panel layout.
Situation:
As of now fuses that have no power but no blown fuses are 3, 4, 7, 8, 27, 28.
Other Info:
checked power distribution block and fuses are fine maxi fuses are fine.
* 1995 ford ranger 4.0 V6 4x4 XLT, i ve attached a pic of the fuse panel.
Situation:
Other Info:
