WCB2 (Walnut Creek)
Chad uses the good buddy system over there, and he know's everybody by the first name!!
SVT
Hey, somebody's got to be the trail guide....:D
SVT
Because I'm an old man with a poor memory & I'd like a gauge to tell my dumbass to stop at the pumps, when the aforementioned Sensei is not with me, before I run out & don't make it to the trail? :icon_idea:
On a technical note concerning sending units;
They do work off of whatever voltage system they are designed for (there are some 6v systems) and they are not real conducive to interchange.
They are however designed & operate on a resistor system & develope/operate at different ohms. I'm not familiar with who uses what, but I do know that Ford & chevy are different. Also all the HDs I've worked on, some for certain years do not work with other years. It's hunt & peck, or test with ohm meter & specs chart to make fit.
As the float rises & falls it developes & transmits a different voltage to the gauge causing it to rise or fall in accordance with where the float is. If the 2 are not conducive to each other, you will get incorrect readings.
Contrary to what some of you TBers may think, I know more about all this shit than you think I do.
agreed, i was just referring to the pump side of the sending unit, i stand by the gauge being un needed, i see your side of the coin... you should always head IN to the bush with a full tank of gas... my pre-trip fillup is usually 100$ 65-70 liter tank, 20 liter jerry can (just incase) and 1.11$ a liter, sometimes more
UPDATES! i wanna see some tubbing getting done
tube, engine, axles, anything at this point :icon_thumby:
maybe I should just trailer down that other Ranger in my back yard....since a slot has opened up on the "Projects List"....and in the field...:icon_rofl::icon_rofl::icon_rofl:
l8r, John
Yeah, that might get extended by a week, this week kind of got blown apart. Today is the first day of this week that we got to work on it, and monday will be another day down as we're hitting the junkyard for a fuel cell...
SVT
somehow i think you missed your completion date :icon_rofl:
l8r, John
Bring it down, John. I always have more room for projects :D
Actually, it has been blown way out the water. Do to some difficulties with Jay's retirement and a multitude of appointments that came up, it's gonna take a tad more than 3 weeks for completion...On the flip side I think I have found a simpler way to the fuel sending unit problem as well as adapting the Ford high pressure EFI fuel lines to the new fuel tank....It's at Chad's now getting the fuel neck relocated...
SVT
Which will depend on what point I will be sober enough to weld it up this weekend...:D!
The wife and I both have the weekend off and that means lots of beer & Bloody Marys.
You did want that filler on the bottom .....right...:icon_confused:....:icon_thumby:
:thefinger: :thefinger: Follow the hole!! :icon_rofl:
SVT
Frame got pressure washed today. What a mess.
Get after it with the grinder tomorrow to remove some stuff that isn't going to be used before it gets some POR-15. :shok:
WCB2 (Walnut Creek)
bam!
i just posted a pic!
