firenexx
- May 29, 2010
Hi folks, I'm driving a '94 Mazda B4000 4.0L V6 with 167k miles. Manual, w/ broken A/C.
My cooling system is pretty screwed up. The radiator is leaking intermittently, I think something else is leaking coolant (not sure what yet) and the fan clutch tends to function incorrectly after about 30 minutes of highway driving, leading to overheating. Right now I'm losing coolant at an annoying rate.
I have a new radiator and upper/lower hoses coming in the mail. I have a new fan clutch that I attempted to install, but I had a little issue: Manual says thread is LH, shroud says RH. Since I'm stupid, I decided to go with the manual (before you say anything, remember, I admitted stupidity as the cause.) And well you know how those things go. Now I have a hopelessly stripped fan clutch bolt, and it's such a low clearance area that I can't seem to figure out any way to loosen it. Nothing fits in there except the tool that stripped it.
I don't really want to go somewhere and pay some dude a couple hundred bucks to fix it. So here's my crazy idea: For far less than what I'd pay for labor, I could buy a brand new or reman. water pump. I could remove the water pump/clutch/fan assembly all in one piece. Then I could slice and dice the water pump off of the clutch and remove the fan. Reassemble with new parts and I will live happily ever after.
So am I missing something? The manual says to remove the fan/clutch before removing the water pump, but perhaps this is just for convenience/ease. It looks like all 12 bolts could be accessed and removed with the fan still on there. It would be tight but I think I can make it happen. Is there some obvious thing that I'm missing, or has anyone tried this sort of thing before and found out that all the bolts are in fact not accessible with the fan still on? Any wise guidance would be much appreciated.
