Water pump and radiator replacement help
hose pipe
LYNCHBURG
TN - USA
Vehicle
Drive
2WD
3.0 V6
First of all apologies as I'm sure this has been answered before..
I will be replacing the radiator and water pump on a new to me 2001 Ranger 3.0 v6. I plan on replacing both radiator hoses, the thermostat, drive belt and the fan clutch. I was curious what else I should replace while I'm in there. Also will 3 gallons of coolant be enough to fill it back up? The truck has 90,000 miles on it. Thanks
Check the drive belt tensioner
I should add...
Are you changing the water pump and fan clutch because they're bad?
Or doing it for maintenance?
If it's fir maintenance... I wouldn't. Those factory parts are likely better quality then any aftermarket part you can buy.
The radiator is leaking and figured I would change the water pump while I had it out. I can get a motorcraft water pump and fan clutch on rockauto. Are they not good quality these days?
