runrunner
- Jul 28, 2012
I have noticed water in my oil cap on my 1990 Ranger 2.9. The white milky substance is there too, but just a little bit, it doesnt coat the entire cap.
Water actually drips out of my cap when I shake it after taking it off. Weird.
The truck doesnt overheat, it actually runs really cold. Sits just above the cold mark on the gauge and stays there. I changed the oil and it was not milky. No smoke out of the tailpipe either.
- My trip to work is about 2 miles so the truck doesnt even warm up before I shut it off.
- Heater core is bypassed since it leaks.
- Mostly water in the radiator since the heater core failed and I havent replaced it yet.
- Heavy valvetrain noise so it doesnt always run fantastic.
- New PCV valve
At first I was thinking headgasket, but after doing some reading it sounds like the condensation could be from short trips? I add water to the overflow about 1x per week, but its probably not more than a cup or two at a time. I've also noticed that water leaks out of the weep hole on the water pump.
Thoughts? I know I need real coolant in there so no lecture on that one.
- New PCV valve
