eighty6gt
- May 5, 2015
So many threads on this, I've searched and searched.
Truck will fire and run on brake cleaner as long as I'd like it to.
I didn't have my fuel pressure gauge in town (it's here now but I don't have the damn fitting to go from schrader to whatever it's got on it....) I have another 3.0 ranger, I pressed the schrader -seemed to be a lot less pressure in the broken truck. Suspected fuel pump. Changed pump and filter. Same behavior. Jumper fuel pump, can hear fuel rushing through rail with truck off. Maybe the regulator is bad and it's allowing fuel to free flow? I will try to borrow it from my good truck and see. Not sure if it's integral to the rail.. I don't think so.
Read that the synchronizer can cause the ecu to not trigger the injectors if it doesn't send the signal after startup. Replaced that, same behavior.
Suspected the crank sensor could also be needed for the ecu to fire the injectors. Replaced that, same behavior.
I'm down to:
- ECU power, which probably isn't it as the truck runs on brake cleaner. Broken ECU?
- ECU looking for oil pressure in some parallel circuit besides the dashboard (which shows all good,) and shutting engine off? (this is folklore I've read.)
I'm at a loss, I think I will have to part the truck out.
Thanks!
I'm down to:
Thanks!
