Washer Jet Adjustment?
HRTKD
Denver area
Are the washer nozzle jets adjustable on a '91? I put the end of a paperclip in there to make sure it wasn't blocked and I then tried to move the jet around to adjust where it was shooting (washer fluid shooting over the cab and into the bed doesn't do my windshield much good). Neither jet seemed to move. Maybe they're just so old that they are permanently stuck.
They should move, actually...spray in some wd-40 or other because the little aiming device could be stuck...I usually use the open end of a safety pin on mine...and they move quite a bit...but that is an 88...they may have modified something in the later years, but I think they are similar...
Thanks for the confirmation. Mine must be stuck solid if yours move with a safety pin. I'll give the WD40 a try.
